- Oct 28, 2018
- 124
What would cause all the kerf on one side of the blade be worn off. The guides are in the proper position the thrust bearing meets the blade to limit movement, and the tension is proper. There is nothing in the housing that could rub the blade. Operated in low speed. setting. The blade was only 4 weeks old and used infrequently on mild steel and aluminum.
