I have a rather cheap and old Craftsman 109 Lathe that isn't a prized pig by any means, but I think it would be a good project/challenge to see how precise I can get it, and it's of a ship-able size if I decide to sell to move up in the lathe world. Ways are 3" by 22" and I only have a surface plate of sized 12" x 18" x 3". It's used, A Grade but I would like to check it's accuracy. Any size larger would be outside of my budget. I'll probably need a precision straight edge, but those are quite expensive as well, and I paid 125 for this little lathe I'm thinking about buying an old cast iron carpenter's level and scraping it in as a parallel, or looking for an off cut of durabar or other grey cast iron and making a straight edge, another exercise to learn. I am a member of a makerspace so I have access to larger lathes and mills there if I need to machine down raw stock.
This thing is little, so I don't want to put a grand into precision tools that are application specific. I have a bench grinder and some other motors/arbors for a diamond wheel, and I got a good amount of C style carbide lathe tools that I plan to shape into scrapers and braze onto handles (based on Oxtools Monday night meatloaf 118 about 45min in). Eventually building the Keith Rucker style hand scraper if I take a knack to it. I also got a set of EZE diamond laps and diamond files. for measurement have a set of Gage Blocks, digital calipers, 123 Blocks, V Blocks, Sine Bar, Vernier and Dial Height Gauges (Browne and Sharpe that I plan to restore), and I am picking up some Vintage Brown and Sharpe surface gauges to restore as well from the same friend I got the Height Gauges from.
My next purchases are for a 6" machinist level (Starret or one of the Shars precision Frame Levels), Precision Squares (or could I get away with the 123's?), indicators (test and dial .001 and .0005, or any recommendations?), Micrometers (probably a 0-4 set), and I need to figure out something to do as a straight edge for flats V's and Dovetails. The ways are double V Style with 3 inches edge to edge and 22" length, which is about an inch over the hypotenuse of my surface plate. I will probably need some shim stock, gauge pins, and other bits and bobs that I have no idea about. I also need to get spotting dies rollers, way oil and oilers, gear oil, and other oils/cleaners, so any advice on must haves for cleaning stripping and oiling would be greatly appreciated.
I know I should get into a class or find a mentor, but I really want to test the waters, and many of the things I own and plan to get are things that I would need to own anyway as a hobby machinist. Abom79's Video with Lance Baltzley along with Stefan Gotteswinter and Robin Renzetti have been great resources.
Finding good cast iron references at affordable prices is the biggest financial hurdle for a novice like myself. The Granite surface plate I have and know I can continue to make use of, but spending hundreds on castings in a hard decision to make (hence considering turning an old cast iron carpenter level into a parallel/straight edge)
I plan to get a pair of these stones based on recommendations you've made elsewhere:
In Stock
Price: $15.51 ea.
Item Notes
MSDS Available
Sharpening Stones; Stone Material: Aluminum Oxide; Overall Width/Diameter (Inch): 1-3/4; Overall Length (Inch): 1/4; Shape: Round Edge Slip; Grade: Medium MSC Part #:00579425 Brand:Norton Big Book Page #:1054 Mfr Part #:61463687150 "
In Stock
Price: $15.51 ea.
Item Notes
MSDS Available
