- Mar 15, 2019
- 708
https://chicago.craigslist.org/chc/tls/d/chicago-metal-lathe-and-accessories/6925754056.html
$220 for a 20x84" Springfield
I've seen that use as a multi thread gear, almost like a worm. That would be some serious saddle movement, not for the rookie thread cutter.Am I seeing that right- it does 1 tpi? that's a coarse thread
A shop that did several drive shafts back in the 70's, had two lathes tail end to tail end. Each lathe could be used by itself, or for long shafts, they turned the tail stock of one around, and between the head stock, and carriage. They also had a special pieces that looked like a steady rest, but held bearings for the center bearing on a two or three piece shaft. I saw them cut, welding, and truing drive shafts, but never got to see how they balanced them.I'm still looking for something like that for drive shaft work. Mike
