Bearing Ball with Flat for Vise work...?
I made this, from some 2" aluminum round bar , to hold tapered tubes for bicycle frame building, but you could use one half to clamp any uneven material in the vise. The V-groove is obviously not necessary for clamping flat objects.
Ok, I just took it out the box. I take it back, it's not ground. It's made for 6" vises so on my 5" vise it sits above the vise jaws slightly. One day I'll take it apart & mill it down so it sits below my jaws. Pretty cool idea but I definitely could live without it especially for the price it sells for. Oh well. I'll keep using the alumn rod that I've always been using.
Aren’t those springs? In your pic, they look like screws? I have seen that thing for a while now. Always wondered about using it on a really angled project. And having the project squirt out of the vise. I’m like you and use the round aluminum rod. Using a steel bearing ball is OK I guess. But I would be concerned about the divot/dent it can leave in your work and or jaw…Dave
View attachment 230776 View attachment 230777
I like that, but question, does it hold steady, being that it is round. Whenever I clamp round I wind up using a V block to steady it.
It has worked well for me, but I haven't tried any heavy milling with it. I just use it to hold the tube for slotting or coping the end with a hole saw. Another framebuilder makes a set of blocks that has one flat v-block and the other round, but that forces the tube to be angled with respect to the vise jaw.
Awesome. I've seen ThatLazyMachinist use brass cylinders. Maybe putting a small flat on the cylinders may also work?
It's said that the ball bearings do indent the work, so maybe I'll try brass or bronze (if I can find bronze spheres).
In any case, the final result should be a nice square piece if work. The ScrewyBall set is sold out on Ebay. The set came in a fancy wooden box, 3 sizes. McMasters sells low carbon bearing balls that they say are machinable.
If you don't want your work indented, couldn't you put a piece of square brass shim on the work? or will this affect "squareness" on the vise?
How are these very hard BB's flat ground ? I don't have a surface grinder and I would like the flat to be, well....flat.
There are many ways to hold your part/project. Yes, the vise is usually the first that comes to mind. But, think outside the box or the use of a vise. Do a workaround. I usually sleep on it and then come up with a better, faster, nicer and more accurate way. Works for me…Dave
I'm not worried about holding, I have clamps for rounds or balls. What kind of abrasive on Rockwell C60 bearing balls?
I don't have a surface grinder?
I'm pretty sure your fingertips to elbow, along with the grinding device needs to be calibrated.:D
I think since we are holding a part that's uneven, just gripping the BB and holding it against a belt sander or flat sanding/grinding disc will produce the flat needed.
... If you don't want your work indented, couldn't you put a piece of square brass shim on the work? or will this affect "squareness" on the vise?
... How are these very hard BB's flat ground ? I don't have a surface grinder and I would like the flat to be, well....flat.
The dent is just a consequence of applying thousands of pounds of pressure at a single point. If you use a ball, you are going to have a dent in the work. This dent is cut off when you square the face it's touching anyway so no big deal. On my little 4" Kurt vise, just 30# of clamping force (not much at the end of the handle) results in over 4,000# of force applied between the jaws - a dent will happen!
The flat can be ground on a belt sander and it is important if using a ball bearing. If you don't grind the flat you WILL dent your jaw face.
The balls that I have are very hard and trying to hold a little 3/4" ball in your fingers while trying to grind a flat on a running belt is ... interesting. If you like, you can make a simple holder. Find a piece of tubing or round rod and chamfer the inside of one end and just set the ball in it. Use the tubing/rod as a handle to push the ball into the grinding surface. Just grind the flat and turn the machine off before removing pressure on the ball. Voila - a ground flat and no meat lost.
The ball is useful when all the surfaces you're trying to square are rough and/or irregular. It allows the greatest amount of rotation to bring as much surface area into contact with the fixed jaw of the vise; that's all it does. If you're squaring stock with nominal square faces, such as square or rectangular stock, a round rod is more than adequate for the job and will not dent the work piece. It is wise to use aluminum for this rod; brass or steel is hard and may dent the work or the vise jaw. I suggest you NOT use wire for this; it is too small and soft and will likely be flattened against the work and there goes your round pivot.
