You would think a guy my age would know something about bearings. Apparently not. I decided to change spindle brgs. on a light Craftsman (Atlas?) drill press, with the intent to cut down on radial play. Easy right? USA made Federal numbers don't interchange on any of the usual bearing sales websites. OK, just type in dimensions, right? Well that's wherein comes the rub. Manufacturing tolerance specs are frequently not quoted, sometimes the term "standard" is used, occasionally ABEC 1, which looking at the charts, should be fine. But I don't know what is ideal. Common logic would suggest that a ball bearing is designed for radial forces and thrust is secondary, hence, would a fellow need to spec a "deep groove" which may be more amenable to thrust forces? Then, new to me, ceramic bearings? Really?
So anyone with an opinion, shout out. I'm used to ordering by part number and spec' ing bearings from scratch is not for the ignorant. Thanks, Paul
