[4]
Before There Was Calculators.
  • Thread starter Deleted member 18150
  • Start date
[3]
[10] Like what you see?
D
Guest - Please Register!
Found this round slide rule under the bottom drawer of a Kennedy box. I had a hard enough time learning the basics of a normal slide rule many years ago.
*********Just Saying**********G*****************
Dinosaur Engineer
Active Member
Oct 21, 2014
42
The flat disc slide rule works on the exact similar principal to that of the linear slide rule. If you can use a straight linear slide rule you should be able to use type.
A further more accurate slide rule was the drum slide rule used by a lot of Drawing offices. These had the logarithmic scales on the outside of a drum which could have a scale length of 500 " as opposed to the 10" normal straight linear type. Sure was a lot quicker (though not as accurate) as using log / anti-log tables ( 7 fig. tables in the D.O. !)
Happy days !
silence dogood
Jul 10, 2013
410
In hi school, I had one of those. As for being accurate, yes and no. In 1972, I took an electronics theory course. In many cases, there were a series of calculations. The guys who spent about 250 bucks for a scientific calculator many times were farther from the answer than I was with my old slip stick. The calculator took it to too many decimal points where as the slide rule would automatically round it off. Mark
kvt
Oct 21, 2014
2,064
Ok, are we dating our selves again, Now days I do not think they know how to use a slide rule, (it would take me a little to remember as it has been so long). I had one like that that I used in high school doing engineering and drafting. Of course we had the old T square, Bottled ink with the dropper, and such. None of the fancy stuff.
Smithdoor
Dec 23, 2012
435
I still have one today use it back in the late 60's
Still works today and battier need
Dave
Danb
Newbie
Jan 23, 2015
8
Had one in high school, used one for the first two years of college--couldn't afford a calc. Carried one in my shirt pocket as an engr in gas plants--because it was intrinsically safe. Probably still some chicken scratch on the I-beams of those plants where I was trying to keep track of the decimal points. The good old days. Still have a couple and still use them.
davidh
Jan 23, 2012
1,216
i can certainly relate, remembering the first electric calculator we got. . . i think it was a remington. still have my slide rules in the desk.
Cactus Farmer
Sep 24, 2013
396
Rule #1, Slide rules need no batteries!
My first really good calculator was an HP35. Reverse polish is better in my opinion..........I miss it still.
David S
Nov 18, 2012
1,319
I grew up using the linear slide rule at University. Mine was a K&E, others preferred the Picket, and there was a laminated bamboo Japanese. My first work term was with a British Engineer and he was using a Curta. I never mastered that one.
https://en.wikipedia.org/wiki/Curta
David
RJSakowski
Feb 1, 2015
3,857
I still have my first Picket N902 and the over-the-top Picket N4 Log Log Dual Base Speed Rule along with its holster. I can't remember having used the hyperbolic or log-log scales but I did use the rest of the 29 scales.
One of the problems with linear slide rules was when performing chain multiplications or divisions, you could run off the scale so you had to slide the slide over to the side to continue. The circular slide rule just wrapped around so it eliminated that inconvenience.
I designed and built a custom circular slide rule for my ex, many years ago. It calculated the length of bar stock required to make a horse shoe, based on the dimensions of the horse's hoof. The scales were printed on adhesive backed Mylar and glued to aluminum backing , the product being sold to farriers.
It is amusing to show the slide rule to some of the newer engineers. I like the quizzical looks it generates. Same goes for log and trig tables.
Chip Hacket
H-M Platinum Supporter ($50)
Jul 12, 2015
189
Need help! I can’t find the Equal Sign.
vocatexas
Active Member
May 8, 2017
158
Several years ago I had taken my mother to a doctor out of town and she saw an antique shop she wanted to stop at. I went in too, and saw a strange device like I had never seen before. I think it was marked $25; if that isn't it, it wasn't much more. I didn't have a clue what that thing was and left it on the shelf. About three years ago I ran across something about Curtas somewhere and remembered seeing that one in the antique store. Still kick myself for not buying it. I just had a feeling it was worth something and talked myself out of buying it.
homebrewed
Active Member
Jul 28, 2017
212
I used a circular slide rule all through college. The HP35 was introduced when I was a Senior EE student but was way too pricey. I still have the circular (somewhere). At work I'd occasionally drag it out to show to my younger colleagues, telling them it was a calculator that worked without batteries.
DiscoDan
Jul 16, 2018
366
I was at an antique store in Frederick, Maryland yesterday and the guy had a very large slide rule that looked to be maybe a teaching aid and it was about 4 feet long by about 10 inches wide and everything worked. He "only" wanted $495!
Bi11Hudson
Artificer00
Feb 13, 2017
283
Still have my Deitzgen engineering slide rule. And still like RPN over algebraic calculators. My slide-rule is in a glass front case with a hammer attached. And a sign saying "In case of computer failure, Break Glass". Never went to high school, picked up the EE offshore a few years later. Guess I missed all the fun of high school... ...
higgite
General Manger - Proofreading Dept.
Aug 15, 2013
900
I still have my Post bamboo slide rule from when I was in college 100 years ago, complete with leather scabbard. If you ask today’s kids, “If Joe and 10 of his friends each had 4 calculators, how many calculators did Joe have?”, they’d reach for their calculator.
Tom
tcarrington
Making miscellaneous parts for years now
Dec 27, 2013
71
Took course in engineering curriculum - nomography - we learned how to construct the "on paper" calculators that you laid a ruler across and connected the quantities you had making the ruler cross another line with the quantity(ies) you wished. Miles per gallon calculators are an easy example. Design of pressure vessels is a complicated one. Any equation can be represented with such a chart. It was a very informative course taught by an excellent professor and it explained a whole lot about how the world works and how we approximate it to our best benefit. Now we use spreadsheets and apps to generate these types of short cuts.
RJSakowski
Feb 1, 2015
3,857
Back in the eighties, I designed a circular slide rule the would calculate the length of bar stock required to make a shoe for a horse, based on two measurements of the horse's hoof. My ex, who was a farrier, made and sold quite a few of these to other farriers.
Downunder Bob
Staff member
May 16, 2016
1,077
Slide rules, used to love them. As a Marine Engineering student at Sydney Uni (Australia) in the early seventies, calculators were very basic and we weren't allowed to use them anyway. So it was Long hand, Log tables or a slide rule. The slide rule was by far the quickest, you just had to be careful when keeping track of the decimal point. They were in their own when it came to doing calculations involving raising a value to a power that was not a whole number as in 2, 3, 4 etc. calculations on the expansion and compression of gases in particular often involve a power of 1.3 or 1.4 etc.
I still have a couple of good old Japanese bamboo slide rules, they were the best. And a circular one as shown above, they were particularly good at trig calculations,
RJSakowski
Feb 1, 2015
3,857
Happy days !
I used five place log tables a lot on college when we needed more precision than the slide rule would provide. One can appreciate the seven place tables when you realize that every additional place multiplies the number of pages of tables by ten. My five place tables in the CRC Math Handbook require 20 pages.
One can also appreciate the power of the modern calculator. The Android calculator on my phone displays 11 decimal places. To replace it with a set of log tables would require 20 million pages.
JPMacG
Mar 22, 2014
372
I was taught to use a slide rule, trig tables and log tables in high school. Scientific calculators were just becoming affordable when I started college in 1974. I think the day I got my first scientific calculator rates among the happiest days of my life, along with the birth of my children, etc. I have never looked back with nostalgia at slide rules or tables. I have not used them since 1974 and I have no desire to ever again :D
ch2co
Grumpy Old Man
Jan 9, 2013
954
You guys got me thinkin' (dangerous) about the distant past when slide rules ruled. I went digging around in my calculator drawer and found
a circular slide rule (from high school) my dad's very old wooden slide rule, three 6" mini slide rules??, my trusty log log decitrig that was a requirement to have hanging on your belt if you were a dedicted engineering student, and somewhere i have a cilendrical slide rule that if "unrolled"
woul be like 5 foot long (for greater accurcy). Then came my piece de resistance, my Curta mechanical hand cranked calculator which was a dream to use when I was on surveying crews. Then of course came the HP electronic hand held wonder that I have 4 different models of. jeese! Totally rediculous, except for the fact that I looked up Curta calculators online and the dang things are going for between 1000 to 2000 bucks! Thanks for making me dig into the collection!
one last thing I have to mention that I learned in high school:
As the animals left the ark, Noah told them to go forth and multiply. After some while, Noah happened upon two snakes sunning themselves. "Why aren't you multiplying?" Noah asked. The snakes replied, "We can't, we're adders."
So Noah and his sons went into the nearby forest and felled some trees. They made a platform of logs onto which they placed the snakes. You see, even adders can multiply on a log table.
Sorry
Downunder Bob
Staff member
May 16, 2016
1,077
Sorry
Yes I also have a few old slide rules including a circular trigonometry special, and a Sun Hemmi, a very nice engineering model from around 1970.
That story about the ark is very funny, do you mind if I copy and share it with some friends here in downunderland.
ch2co
Grumpy Old Man
Jan 9, 2013
954
Well I stole it from somebody so steal away! It’s too good not to share.
magicniner
Oct 21, 2017
475
I still have my slide rule, it's great for very quick, fairly accurate figures.
Downunder Bob
Staff member
May 16, 2016
1,077
ch2co
Grumpy Old Man
Jan 9, 2013
954
silly! A Kennedy Box is a box you keep Kennedys in.
Kennedy is a brand of tool boxes. Typically painted brown with many drawers to keep (and loose) tools in.
Considered as a must have by many.
Downunder Bob
Staff member
May 16, 2016
1,077
As in used politicians.
I get it It's just a brand name fro a generic draw type tool box. We have similar here but different brand names usually named after the big box hardware, and auto parts stores that sell them. And if you've got more money than brains, you can get them with names like Snap on.
In my day we made ours out of scrap timber, still got mine was made in 1961 while first year apprentice.
ch2co
Grumpy Old Man
Jan 9, 2013
954
Yeah Kennedy’s have almost a cult following. They go WAY BACK in time. I have two of them. They are primarily used for bench top small tools. They also make a lot of other style general tool boxes I’ve got several. One for plumbing, one for electrical, one for general carpentry etc. 3 of these are red and two are brown., but when I think of Kennedy cases I usually think if the bench top units.
Downunder Bob
Staff member
May 16, 2016
1,077
I get it. As I said mine is similar style but made out of wood, i'll get a photo of up here sometime. Some guys who were good at sheet metal work made their own in that style, Nowadays they just buy them fro the big box store.
[6]
[5] [7]
