[4]
Best Way To Mate A Grizzly/bald Eagle Spider To Backplate
[3]
[10] Like what you see?
Bamban
Jul 13, 2014
738
Likes
617
#1
I am putting together a Taiwanese 10x24 lathe, the project includes VFD/3P system and building a spider chuck. The lathe was gifted to me motorless and chuckless. BIG thanks to our member, mksj, the motor part is under control.
For the spider chuck I finally found a backplate on eBay, and bought the Grizzly 5 inch Bald Eagle spider chuck. The problem, though both have mounting holes in them but the bolt centers do not match, I have to drill and tap the back plate to match the spider mounting holes. The center holes are different diameters.
The question. What is the best way to set up and mate the 2 pieces together and ensure the they are on the same axis when bolted together Federal PC 23 10x24 Backplate.png Bald Eagle Spider.jpg ?
kd4gij
Feb 7, 2011
4,674
Likes
1,848
#2
To answer we need to know what tools you have to work with. I would mount the back plate to the lathe and use the tail stock with a live center to hold the chuck to the back plate. indicat it in and use a transfer puntch to mark new holes.
Bamban
Jul 13, 2014
738
Likes
617
#3
Thank you.
I have a Bridgeport, super spacer with 3J, rotary table, a Blake, a self centering Bison vise, Kurt 6 inch, and drills and end mills.
The problem the lathe I will use this is not in operation yet, I need to finish this spider so I have a chuck to use when I start checking the lathe out.
I have another lathe but it is a D1-4 spindle.
Could I do this on the mill?
kd4gij
Feb 7, 2011
4,674
Likes
1,848
#4
Shure you can do it on the mill. A couple of ways with what you have. If you have a dro that does bolt circles would be one way. Or you you have a rotary table.
You can use that center the back plate on the RT in the mill. mesure the bolt circle of the chuck end drill it. Scence you have another lathe you could make a pluge to screw in to the face plate and slide the chuck over it and drill the holes that way.
kd4gij
Feb 7, 2011
4,674
Likes
1,848
#5
What are you going to use that chuck for. I looked on grizzly's site and thay say chamber reaming small barrels. But it doesn't look like it will hold well enough for any typ of machining.
Bamban
Jul 13, 2014
738
Likes
617
#6
Thank you.
This is the first attempt for me to mate these 2 pieces together, I appreciate the options you brought up. I have to see if the DRO has the capability to do bolt circles.
kd4gij
Feb 7, 2011
4,674
Likes
1,848
#7
When I have to drill a bolt circle eather wth adro or RT I will take a spotting drill and lightley marke each hole and check it before I drill it.
Jimsehr
Apr 23, 2013
419
Likes
335
#8
I would mount backplate . Then counterbore the 6 inch backplate just enough to capture the 5 inch dia of the other plate. Then drill holes on mill. jimsehr
kgowedan
Newbie
Feb 2, 2016
17
Likes
17
#9
Thank you.
NOTE - you can't fit the Bald Eagle BE1125 spider to a D1-4 back plate, as it is drilled for four (4) holes and the D1-4 back plate is three (3) hole arrangement. No mater how you turn it, it will not clock (lign-up) without touching a hole in the back plate for drilling/threading/mounting. The only way is to get an extra thick backplate or use a thick faceplate that will allow you to drill up to a hole on the opposite side with out interfering with the D1-4 locking tabs/pegs. The Bald Eagle item is useless!
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
808
Likes
531
#11
This may be a stupid question but why would you want such a device?
Please explain this.
Bamban
Jul 13, 2014
738
Likes
617
#13
You resurrected a 3 year old thread. I have since finished the 1024 VFD project and the Bald Eagle spider lives in the lathe sort of permanently. I have this 1024 dedicated for chambering AR15 barrels, 94 count to date. The Bald Eagle serves me well.
BTW, the 1024, as I showed the backplate in the original post, is not D1-4 spindle, it is threaded. As you can see in the pictures, I end up using a faceplate and just bolted the two together. So far the bolted scheme is holding tight.
When I said dedicated, the compound is set precisely to bore a taper the same as the cartridge body taper. I drill then run the micro100 carbide mini boring bar 0.050 short to the shoulder, finally run the finishing reamer, and set the headspace. For threading the little 1024 does a nice job plunging in with the cross slide with the barrel held by the spider.
Besides this 1024 lathe, I have 2 larger ones for contouring, as well as for chambering other blanks that won't fit through the 1024 spindle bore.
Bamban
Jul 13, 2014
738
Likes
617
#15
I understand what it does, will an independent 4 jaw chuck not do the same job?
Yes it can, more ways to skin a deer.
If you look how I use the spider, those little finger clamps with ball bearings allow the chamber end of the barrel to pivot when dialing the outboard spider. Then again many good shooting barrels were chambered on steady rest. What works best? It is whatever you are used to driven by the limitations of your lathe.
kgowedan
Newbie
Feb 2, 2016
17
Likes
17
#16
I ended up getting the South Bend "thick" backplate from grizzly. http://www.grizzly.com/products/6-1-4-D1-4-Back-Plate-Thick/SB1394 . The extra thickness of the back plate will allow you to mount the Bald Eagle Spider using the four mounting holes of the Spider without interference with the three D1-4 mounting studs. They should have put more thought into the making of this Spider, guess that's why it is listed as discontinued in some places to buy it
[6]
[5] [7]
