Best Way to Mill an Angle?
I need to mill a 7º and 11º angle on the base of a round stand-off. While I could tilt the head of my mill, I'd rather not have to re-tram. What are other ways to hold a round piece in a vise at an angle for milling?
This is what I have:
This is what I need:
Thanks in advance.
Unfortunately I don't have a collet block, but mebbe I can make something. After noodling on it, I'm thinking of taking two pieces of aluminum, clamp them face-to-face with tape or paper between them, bore a hole normal to the top, rotate the aluminum to the correct angle, and mill the top so it will sit flat in the vise when it holds the standoffs.
I do have an indexing head, so maybe just make something to clamp the standoffs and bolt to the indexing head would be easier?
Thoughts?
I just picked up a nice little Palmgren angle vice that would be perfect for that. Another way would be to clamp a small machinists vice in your milling vice on an angle.
This will work, or you can cut a V like mmcldl said and use that. I like a small vise bolted to a tilting angle table so that whatever I put in the vise is held solidly and square to the vise.
Check out the sine vise I made from a normal bench vice, it's in the POTD thread. You just elevate one end by the right height to give the angle you want. It's about perfect for this problem.
