- Mar 26, 2014
- 1,491
I am rebuilding and old pto driven gear box on a buzz saw. There is an input shaft and two output shafts. One at 90 degrees and the other out the backside ( not sure why ) I have it all disassembled and need to replace the bearings. I have two bearings out. ( see post in questions, about stubborn retaining ring).
The other two bearings can’t be removed without first removing the bevel gear. The gear is keyed. Can this be pressed off? What holds it on? There are no snap rings just the key way. Would it have been put on with an interference fit.
any suggestions I would appreciate it. If we don’t get too much snow tonight I’ll post a picture tomorrow
Thanks
Cheers
Martin
Thanks
Cheers
Martin
