Big And Heavy Lathe
LucknowKen
Jan 18, 2016
398
I wonder how much this machine weighs.
lk
I don't know, maybe 5500-6500#'s. I do know if it were closer it would be on my trailer!
Sent from somwhere in east Texas by Jake!
My 18" x 60" Boye and Emmes Roundhead comes in at around #8000.
Daryl
MN
We're all just guessing here, but since that is a belt drive headstock, it doesn't have all the shafts, bearings, gears and shifting mechanisms to add to the weight, it doesn't appear to have a QCGB, so there is a few more pounds off.
It's still a good sized lathe, and a lot of cast iron, built back when they were meant to last. Since it has a middle support leg for the bed, that gives another clue. I may be on the heavy side, but I would say 7,000-7,500#. Can't see if it has a taper attachment. That would add a couple hundred pounds once it was mounted and all modifications made to fit it. No steady rest, so knock off some. It's really hard to guess.....especially not knowing who made it. Some makers went out of their way to make a heavy, rigid lathe, and some went in the opposite direction.
If you find out for sure, please let us all know.
Would be nice for building/balancing drive shafts for cars and heavy equip. Mike
