So I heard from Matt at PM: He was a bit shocked that the motor took that kind of hit. He then said he'd help with any parts I need (in the original mail I told him I was going to try to salvage it), but then said that because that looks pretty bad he should just send me a new motor. Just like that.
So right after that I get a invoice marked 'Paid' for a new 3hp motor. He said that he just received the next shipment of lathes and it make take him a bit to find it but he will send it out ASAP. How's that for customer service?
Yup, that's why I am loyal to Matt. The motor on mill died one day. I called him & he offered to send me a new motor without hesitation. Turns out it just blew a cap so I didn't need it.So I heard from Matt at PM: He was a bit shocked that the motor took that kind of hit. He then said he'd help with any parts I need (in the original mail I told him I was going to try to salvage it), but then said that because that looks pretty bad he should just send me a new motor. Just like that.
So right after that I get a invoice marked 'Paid' for a new 3 phase motor. He said that he just received the next shipment of lathes and it make take him a bit to find it but he will send it out ASAP. How's that for customer service?
Love your avatar Mark. I have one very similarly marked.
Not a great deal accomplished today. I hoisted the three phase motor up on the bench and removed the fan cover. There is a cheesy plastic fan in there that I doubt any impact would hurt, and there is no visible damage to the motor case anywhere. The motor shaft turns freely. So I think all I need to do is scavenge the fan cover from the single phase and swap the motor spec stickers.
I removed the gear cover from the left side of the lathe and cleaned the gears and started checking the drive belt this thing came with. When I was first attempting to turn the chuck it was really weird in that you could move the chuck a bit, release it, and it would promptly back up. Turning it more and I noticed definite 'humps' or areas that required additional force on the chuck to get it to turn. I loosened the tension bolt and tried to pivot the motor up so I could get the belt off and promptly ran into what appears to be one of the headstock adjustment screws. What's up with that? So I couldn't seem to get the belt off and in 'one of my moments' I pulled out the Cold Steel folder and solved the problem permanently. Didn't want that belt anyway after hearing the stories here. So I pulled out some linked belt I had in a drawer and make up a new belt that allows the motor to settle down a little further which makes belt changes easier but still allows the cover to be put back on. I don't recall exactly but I think I was in the 26-27" range with the last installed link. Now the chucks spins nicely.
I removed the control panel on the front of the lathe to get a better look at this oiling system for the Norton gear box. Wow, is pretty much all I can say. I've already started a background process in the brain housing group to replace that with something that can more accurately and reliably deliver oil to the gears in the gearbox.
Hey Bill,
Got to dinkin' around with the threading lever & after oiling the crap out of it with no results, I pulled the threading dial for a better look. Found 3 hex screws behind there that appear to keep tension (too much in my case) on the half nuts. The larger one was kinda loose already, & when I tightened it the lever really got stiff. The top one didn't seem to do anything one way or another, but the bottom one, that was the key. Loosened it about 1/4 turn & now the lever moves quite freely. Might want to give it a shot.
By the way, bought a Gates 6926 belt today & it fits perfect. Plenty of slack to swap between pulleys & the cover fits. Yay! Anybody want those 25 & 28 inch belts????? I'll send them to you FREE
Mark
