I am looking at acquiring a Bison C5 chuck. There looks to be two options. A D-5 integrated chuck and a chuck plain back and a D-5 back plate. What say ye of the Bison C5 owner?
I don't own one but C5 & D-5? I assume you mean 5C collet chuck & you have a D1-5 spindle? (jmwy)
Although with quality manufacturers the runout should be low with a integrated mount but if I were to buy a 5C chuck I would go with a Set-Tru. Or to save money a plain back & make it a "Tap-Tru". But really if I were to go with 5C I'd like to have a collet closer instead. I miss using one.
I have a cam lock spindle & the only accessory I have that is integral mount is a 4-jaw chuck. Cause it really doesn't matter being indie & less weight/overhang. Weight/overhang is not a concern on a 5C chuck.
I have the D1-4 Bison set -tru, great 5C chuck, a little more expensive than the TMX. Quality wise also a bit better fit and finish then the TMX, but both are very good. I recommend a 1/64th collet set, the one from QMT tools is pretty decent, there are a few other vendors.
