- Dec 27, 2014
- 4,055
I dont believe the needle bearings can be removed hydraulically. That requires a solid bushing type bearing, no way for the grease to get out, other than pushing the bearing out. the cage of the needle bearings would leak like the proverbial sieve. Before considering removing the bearing I'd look at the shaft that runs in it. If it looks distressed, they it will need ground in addition to replacing the bearing.
