Boiler Gas Spuds
Buffalo21
H-M Supporter - Gold Member
Feb 24, 2018
1,044
A while back I made a set of gas spuds for 2 large boilers, I was told they needed to be 3/8" x 4-1/2" stainless steel gas spuds with (10) 3/16" orifices. Welp either my measuring equipment is on a different standard, than theirs or they made a serious error, they actually need to be 1/2" x 3-1/4" stainless steel gas spuds with (10) 3/16" orifices.
1 - start with 1/2" x 5", 304 grade stainless steel nipples
2 - cutting them to 3-3/8" long
3 - the left overs
4 - the raw stock for the 35 needed gas spuds|505D2E86-E7E8-450C-BF73-5356FCE367F5.jpeg0886FD01-07A2-4AE5-AF6C-5C64CDBAC341.jpegC5180BC9-1946-4B13-AB0C-D77C2EDB48DC.jpeg8CBDB730-F522-4BD1-86F0-57BAA5824FE7.jpeg
5 - power tappig the raw spuds for the 3/8" npt stainless steel plug to seal the end, on the Jet Lathe
6 - another view of the power tapping process
7 - the orifice drilling set up
8 - the drilled gas spuds
9 - the results
for some God forsaken reason the last 3 pictures are rotated 90 degrees to the left.08CA8978-EA58-49F4-B91E-D91F1325CB66.jpeg06ADC568-0FCC-4DB9-A64F-494F2AA357DA.jpeg1D93D200-D863-46B2-8521-EDD1149B11BE.jpeg9E638A02-095B-43A2-98BC-5DE75CE2EB46.jpeg7B2E0FB9-D804-4CB2-99DF-1B9E00A70198.jpeg
the spuds now to be cut to finish length and buff up a tad
cut the spuds to the finish length and rolled all of the sharp edges. They are now ready for the minions to install
here are pictures of what I was told to make and what they actually need859B837D-4FA5-465B-ADD1-CB6139E8046A.jpeg43468EF8-1EEB-4F5B-B04E-55D055D28F22.jpeg
