Hi again, I would like to put a set of tapered roller bearings in my gingery lathe.
Its working fine but its a constant bearing adjustment and sometimes I'll get
a little chatter, usually on the second to last cut and then it wont clean up, that sucks.
I cant bore out the head stock like I originally did unless I remove the head stock and
set it to move into the revolving boring bar, according to gingery.
You guys that have built gingery lathes know that gingery says not to do it similar to
the way I describe below.
Would it work to machine a bar to make sure there is no taper between centers.
Then setup a boring bar to run in bushings in the tail stock and then connect the lead screw
to the tail stock and manually feed it into the head stock.
Once the first section is bored out, install a set of bushing in the hole to support the
boring bar for the last section to be bored.
I have a small motor to set up and run the boring bar or else a drill on slow speed.
Let me know what you think, or any comment about this.
Thanks,
Tim
Thanks,
Tim
