- Oct 29, 2012
- 1,328
I figured out a cool trick yesterday and thought I would share. I'm sure I'm not the first, so if anyone has been doing this for 40 years, feel free to chime in.
When I need to do some boring in a fresh blank, my usual process to get the hole big enough for a boring bar is the long and tedious drilling with a small drill, then a medium one, then a large one, then a really large one, then the boring bar, unclamping and moving the tailstock back each time, opening the Jacobs chuck, sliding the tailstock back and clamping, which altogether takes a minute or more for each but change.
Machining is just my hobby. My livelihood is building electrical panels, so I have lots of step drills laying around, which I have only ever used on sheet metal (to make knock-out holes for conduit and pushbuttons) and I assumed that's all they're good for. But I decided to try and use one to bore out a 1.5" hole, 3" deep, so I can go from [no hole] to [boring bar sized hole] in 1 step. I figured the bit would probably be destroyed, so I used the cheapest one I had, from Amazon. I used plenty of cutting fluid (CRC foaming cutting fluid in aerosol can) and much to my surprise it actually worked like a champ. It was several times faster than my usual approach, and what surprised me the most is that despite the fact it's cutting several holes at once, it was no harder than drilling a single hole. The resistance and the amp draw on my motor was about the same as drilling a 3/4" hole to 1" using large twist drills. Boring that hole took only a couple of minutes and the step drill was no worse for wear.
This step drill will remain part of my lathe tooling from now on, and this will be my new method until I find some reason for it not to be.
