- Feb 15, 2017
- 3
Gang I purchased a 13” South Bend lathe that came with a milling attachment that has the feed screw twisted in two and the brass nut is seized on the threads. I own another milling attachment off of a 16” South Bend. The dovetails are different sizes. I would like to switch the dovetails and see if I can make the bigger attachment work. How do they come off? If it’s just threaded on, are they regular right hand threads and what should I use to keep it from getting the dovetail marred from tooling?
