I tried adjusting the dogs to increase or exaggerate the kick for the return with no success.
The table return works with the cross slide when engaged. There is no change in operation regardless how I have it adjusted.
The manual says to bleed the system by having full table strokes and running it for some time. This I have done.
I'm not aware of any additional bleeding methods which may still be the problem as it sometimes returns normally.
It could be an adjustment, I just don't have a clue.
Not sure about the detents?
Someone mentioned a hydraulic leak, the only way I know of checking is to remove the cover and watch it operate.
I am including a page that breaks out the table valve and some of the hydraulics.
Thank you.
