- Aug 15, 2013
- 2,107
If low speed torque matters to you, in general brushless DC (BLDC) motors have more torque at low speeds than their brushed counterparts. That's why brushed mini machines have hi-lo gear shifts or multi-sheaved pulleys with a set number of speeds available, like the Jet 920. That's to keep the motor up on its torque curve at low spindle rpm. BLDC belt drives, like the LMS, run min to max RPM (motor and spindle) with no gear/pulley shifting. I don't know how the PMs are set up. If you do most of your work at a single speed, it's no big deal one way or the other. Some may say no big deal, period. All 3 of the machines you listed require messing with change gears to do threading.
That said, I had a 7x14 that had no trouble threading at 60-70 rpm in low gear. I now have an LMS 8.5x20. I have turned and faced a 4" aluminum "hockey puck" on it, but most of my work has been turning and threading aluminum, mild steel and brass up to 3/4" round. That is about the largest size that will fit through the spindle. (actually something like 20mm if I recall). It's a very well made machine, as I'm sure the others are, too. A lot of folks on the forum also speak highly of the PM machines.
Tom
Tom
