Lots of little things making slow progress.
Yard got contoured, manure mixed in, a bit of agricultural lime (aka limestone sand), and seeded. Grass has sprouted and we're expecting rain tonight and tomorrow so that should help. Always a bit of a timing game getting grass started in the fall, fall is usually quite dry, and the rain starts just before the temperature drops for the winter. So hoping for a bit of moderate temperatures and light rain for a few more weeks. We're on enough of a hill that we need the grass before winter or the spring rains will erode things badly.
Also installed the fiber cable (internet) to the house. My internet actually hubs out of the machine shop. So 12 strands of single mode fiber in a direct bury cable which is in turn run through 1-1/2" buried electrical conduit. About 350' of conduit, 430' of fiber. I ended up with about 10' of extra in a roll up in the attic of the machine shop, so I did pretty good on my measurements given the fiber was ordered a year ago, i.e., 6 months before the basement was poured.
The yellow tangle is the polypropylene rope we used to pull the fiber through the conduit. It was *NOT* the rope to use. Cheap, and very stretchy at 400'. So we pulled 5-6' of stretch out of the rope to get a few feet of cable pull and then reset. Very tedious. Should have used something like polyester. You can see the thin initial pull string running up the wall at the bottom of the picture. I was kinda fun tying that to a cheap plastic grocery bag and using a vacuum to suck it through the conduit.
Installed the wall mounted rack just above the conduit entrance in the basement. It houses the network equipment, with some room left over for a NAS and maybe a Raspberry PI or two for possible home automation projects. Some more cleanup of that install required, at least a power strip to the outlet rather than the dangling wall warts.
For the LAN geeks, I'm using Mikrotik equipment, courtesy of someone on this forum who got me started on that brand. Quite a bit klunkier tp configure than the Cisco equipment I was accustom to, but the price is right. CRS309 with 8 SFP+ ports in the shop forms the center of the network. CRS 310-8G+2S+ in each of the five networked buildings, all connections at 10Gbps. The 310's have 2.5Gbps copper ports. That's a good bit of bandwidth but it should last me a good long time without needing upgrade. Wifi 6 (cAP AX) access point. Primary use for now is looking up plumbing and electrical parts at Menards, or checking code on detailed issues. Without wifi from the basement I had to either run upstairs or outside to get enough of a cell signal to have usable internet. Even though the house is far from finished, I may move an old lounge chair in the loft and spend a bit of time with my iPad, enjoying the view and browsing hobby-machinist.com, this winter.
