Burner Adapter
Buffalo21
H-M Supporter - Gold Member
Feb 24, 2018
1,044
We have a job coming up, where the customer ordered the boiler directly from the manufacturer, then as an after thought bought the burner directly from a totally different manufacturer. Unfortunately, while they both have the same BTU rating, they do not exactly fit together, their only options are to either, (A) buy another burner (roughly $21,000) or (B) have us make an adapter to make them fit and work together (roughly $2000-$3000). They selected option B.
1 - laid out the bolt holes on boiler plate
2 - laid out the bolt holes and pilot cut-out for burner plate
2 - the plate to the boiler cut out and bolt holes drilled
3 - the plate the burner will bolt to, cut-out, with pilot cut-out and bolt holes833CA298-DBEC-4830-A40D-25FAA48D1402.jpeg021CE151-3BC3-4EF9-8DBC-70D4A3297D08.jpeg4D269202-5607-4F61-89AF-474D8C6A5DDB.jpegB7C90A98-64E3-4F95-90BE-B6375122A0B7.jpeg
5 - welding in the boiler mounting plate
6 - welded
7 - the burner mounting plate, with the studs welded inD232FD45-71C6-469A-BC50-48048FAB252E.jpegA40ACA87-BD5C-4EF6-A759-A6830438B6BC.jpeg0165F304-298F-4EA9-BD10-94B7E5BB1471.jpeg
Bessy clamps, you can't beat them.
I bought about 100 of the small series clamps, in 4”, 6” and 8” lengths from a supplier going out of business, I paid about $5/ea. I also bought some of the bigger series, some 10”, 12”, 16” and a set of 24”, they make great clamps.
Excellent clamp-down table too!
-brino
If it weren't for people like us, the one's that think they are so smart couldn't afford to make poor decisions.
Nice work!
-brino
the table is a Miller 30FX, I have 2 of them (thank you expense acct), I also have 4 of the table clamps that fit into the table slots. The last I knew tables were in the $250-$300 range, they fold up to about 5” thick and about 75#.
