I have the CX601 and have not used it that much. I am however worried about the gears. Without dismantling the machine, I have tried to determine which gears we are talking about from the parts diagram. If some one knows the part numbers for the these and the best place to buy them I would be grateful to hear from them. As well I am wondering where the LMS website mentioned earlier is loacated. My apologies for not being able to figure this out.
BTW, I contacted Busy Bee and they basically confirmed that the CX601 has both plastic and steel gears. Boo.
After reviewing all of the options that are available to me, including driving down to bellingham to pick up a Grizzly, I finally put a deposit down on a CX-601. Yes, it does have the plastic and steel gears. Currently the gears are in stock at the Toronto Warehouse, but they did admit to me that when they are out of stock it can be a while to obtain them. They emailed me the part numbers and (current) pricing of the gears, which I assume you can cross-reference to the parts diagrams at the back of the manual:
pcx601230 $19.99
pcx601209 $29.99
pcx601double shifting gear $59.99
For what it's worth, I'm simply going to buy a spare plastic gear to have "in case", while ensuring that I triple check the gear mesh on each of the gears before and after break-in. Based on what I've been able to find online, problems with the plastic gears seem to be either initial issues (probably didn't check the gear mesh before initial use) or from crashing the machine. My plan of attack is to enjoy the machine as is, and if the gears become an issue, swap over to a pulley setup. It appears as though you can buy a full kit, just the pulleys or make the whole thing yourself if so inclined.
For my order, I simply requested they include "the gear that most often strips out when you crash the machine", which Norm in BC seemed familiar enough with. Once it arrives, I'll post the correct part number and cross-reference it to the 601 part diagram.
-Dave
