- Jun 26, 2018
- 1,733
So to clarify, you took the original Grizzly tool post, tapped and threaded to match the tail stock's stud and you're good to go? I'd be plenty happy with that! I'll have to give that a shot tonight.
Yes I have. Others have also reported the same observation. My cam lock is set to work best in the area where it is most frequently used. However, when the TS is parked at the extreme tail end of the ways the cam goes over center. The cam could be adjusted to work everywhere but I prefer to have the cam at around 11 o'clock when it is working.One interesting thing, and I don't know if anyone has this issue, it wont tighten enough to lock the TS at the first 5 or so inches to the right side of ways. Anyone else run into this?
