- Feb 27, 2023
- 9
indubitably.Stake the bottom thread of any machined tee nuts, it will save your bacon later. If you have ever seen a busted out tee slot, it's enough to make a grown man weep.
Most Mini-Mills only come with two T-Slot nuts (so you can mount a vise) unless you buy a kit. These should work: LMS Mini-Mill 7/16” T-Slot Clamping KitSo I ordered from two sellers on Amazon, and they don't fit. Anybody got a link for inexpensive T-nuts for this machine, US seller, reasonable or free shipping? Yeah, I know, I could just make them, but with all the mini mills being sold, surely somebody is making T-nuts. The machine only comes with two.
There's lots of these kits available. I have a similar 7/16" kit. Can't remember who I bought it from. Oh I remember now. At the time I got my mill this kit was out of stock everywhere. Had to buy a 1/2" set and mill the tee nuts to fit. Wasn't that hard to do, a little bit here, a little bit there and eventually they fit. Was the hard way. Knowing what I know now, I'd just make a single stick of them and saw off the pieces. All your tee slots may not quite be the same. If you make them, get the dimensions of the narrowest tee slot! Oops.Most Mini-Mills only come with two T-Slot nuts (so you can mount a vise) unless you buy a kit. These should work: LMS Mini-Mill 7/16” T-Slot Clamping Kit
Yup, based on measurements of my machine the T-slot width has significant variance. Same with the slot-to-slot spacing on the table.There's lots of these kits available. I have a similar 7/16" kit. Can't remember who I bought it from. Oh I remember now. At the time I got my mill this kit was out of stock everywhere. Had to buy a 1/2" set and mill the tee nuts to fit. Wasn't that hard to do, a little bit here, a little bit there and eventually they fit. Was the hard way. Knowing what I know now, I'd just make a single stick of them and saw off the pieces. All your tee slots may not quite be the same. If you make them, get the dimensions of the narrowest tee slot! Oops.
