- Jun 30, 2015
- 143
I know that to adjust a bison set tru 6 jaw chuck, you lightly loosen screws in front of chuck( loosening back plate). I am having problems making the 4 set screws work. Are the set screws moving the jaw? Sounds stupid but it has to right? . I was under the impression that the four set screws work against each other. But I can’t get them to move jaws. I know with a 4 jaw, after an indicator is attached, you loosen the low end and then tighten the high end. This doesn’t seem to work with my 6 jaw bison set tru. In another post from 2011, a member stated that an adjust tru works opposite a 4 jaw but didn’t build on statement. Can someone explain how a 6 jaw properly gets adjusted.
