[4]
Carbide Grinder by Enco
[3]
[10] Like what you see?
4ssss
Brass
Apr 25, 2017
543
For an extra $50 you can find a Baldor Carbide grinder off Craigslist and not have to rework the entire unit to put a diamond wheel on or to get the tables to move. Look at this video to see what you'll be getting into.
royesses
H-M Platinum Supporter ($50)
Aug 23, 2014
653
I have the Enco version it is the same grinder as the MSC. The instruction manual on mine says to call Harbor Freight for support! I have done a heck of a lot of work on mine so I could use a diamond wheel on one side and a CBN wheel on the other side. The video on the above post will tell you what needs to be done to make it work pretty well. I also had to machine the base as it rocked .200" on a flat surface. I also replaced the cheap motor bearings and put in a spring washer that was missing for bearing preload. The good part is that Grizzly sells the same grinder and also stocks all the replacement parts. On my grinder now I can balance a nickle on end and turn it on without disturbing the nickle.
Roy
Bob Korves
Jul 2, 2014
6,177
I have the HF version of that grinder and mine came running smooth as silk. Had to work on the table trunnions to get them to move smoothly and easily (mostly just adjusting them correctly. I then added a Shars diamond wheel that has a very slightly different bolt pattern and is impossible to get to run true or in balance. I think will take it apart again at some point and add a new and properly centered bolt pattern of the correct bolt circle size on the Shars wheel. The Chinese carbide grinders get mixed reviews because of poor quality control. You might get one that runs smooth or one than wants to walk off the bench. Still, they are a small fraction of the price of the Baldor grinder they are based on.
randyjaco
Oct 5, 2010
824
+1 on the Harbor Freight. I did the same with Enco diamond wheels.
kd4gij
Feb 7, 2011
4,695
In my area you would need at least another $550.00 to get a well used Baldor.
stioc
Active Member
Feb 22, 2017
174
I'll admit I don't know much about grinders. I have a couple of $60 bench grinders that I've used for years. What do grinders like these give you over the cheap ones? Are they just better built (smoother, more balanced etc) or do these have some other major advantages?
[6]
[5] [7]
