- Feb 2, 2017
- 1,234
I think I found my mill--an 8x36 used import, weighing about 1700 lbs. I want it to be mobile so I can roll it around as needed.
I've heard good things about CarryMaster casters. I have a couple questions:
1) What issues would there be if I mount casters to the holes in the base rather than building a frame with outrigger wheels?
2) What safety factor should I use when sizing casters? CarryMaster makes 1680 lbs, 2640 lbs, 4400 lbs, 5700 lbs, and 7920 lbs casters. Obviously the bigger they are, the more expensive they are. I'm thinking that the 4400 lbs set should work ok, but maybe the heavier duty casters will roll easier?
Thanks,
Evan
Thanks,
Evan
