CCMT vs CNMG Carbide Inserts: Which One Should You Use for CNC Turning?
When starting CNC turning, one of the first things many machinists struggle with is choosing the right carbide insert.There are hundreds of insert styles available, but two of the most common turning inserts you will see are CCMT and CNMG.
Both are excellent inserts, but they are designed for different situations.
The right choice depends on your machine rigidity, workpiece material, cutting conditions, and whether you are roughing or finishing.
CCMT Inserts – Flexible and Easy Cutting
CCMT inserts are positive rake inserts. The cutting edge geometry allows the insert to cut with lower cutting forces.This makes them very popular on:
- Small CNC lathes
- Hobby CNC machines
- Manual lathes converted to CNC
- Machines with limited horsepower or rigidity
- Lower cutting resistance
- Better surface finish
- Less cutting vibration
- Good performance on light and medium machining operations
A common CCMT insert size is:
CCMT060204
CCMT09T304
The first two numbers indicate the insert size, while the last digits indicate the nose radius.
A smaller nose radius is usually better for reducing cutting forces, while a larger nose radius can improve surface finish and tool life when the machine is rigid enough.
CNMG Inserts – Strong for Heavy Cutting
CNMG inserts are negative rake inserts with a much stronger cutting edge.Unlike CCMT, CNMG inserts are designed for machines that can handle higher cutting forces.
Common applications include:
- Steel roughing
- Heavy material removal
- Cast iron machining
- Larger CNC lathes
- Production machining
The insert has multiple usable cutting edges and can withstand heavier cuts compared with positive inserts.
Typical CNMG inserts:
CNMG120408
CNMG160612
A CNMG insert with a strong chipbreaker can remove a large amount of material quickly.
However, because CNMG requires more cutting force, it may not perform well on smaller hobby machines that lack rigidity.
CCMT vs CNMG Comparison
| Feature | CCMT | CNMG |
| Insert type | Positive rake | Negative rake |
| Cutting force | Lower | Higher |
| Machine requirement | Small to medium machines | Medium to heavy machines |
| Surface finish | Excellent | Good |
| Roughing ability | Limited | Excellent |
| Vibration resistance | Better on light machines | Better on rigid machines |
| Number of cutting edges | Fewer | More |
Which Insert Should You Choose?
For a small CNC lathe in a home shop, CCMT is usually the easier choice.Reasons:
- The machine often has limited rigidity
- Lower cutting force helps prevent chatter
- Finishing operations are easier
- Less power is required
Reasons:
- Higher metal removal rate
- Stronger cutting edge
- Lower cost per cutting edge
- Better for continuous production work
Small machine + light cuts = CCMT
Large rigid machine + heavy cuts = CNMG
Material Selection Also Matters
The insert shape alone does not determine performance.The carbide grade and chipbreaker are equally important.
For example:
Steel:
- P10-P30 grades are commonly used
- M10-M30 grades are often selected
- K grades are common
- Fast edge wear
- Chipping
- Poor surface finish
- Excessive heat generation
My Experience With Small CNC Machines
On hobby CNC machines, the biggest limitation is usually not the insert itself. It is machine rigidity.A very strong insert on a light machine does not always give better results.
Sometimes a smaller positive insert with lower cutting forces will outperform a larger negative insert.
For example:
A CCMT insert taking a 0.5 mm finishing cut may produce a better surface finish than a CNMG insert that causes vibration because the machine cannot handle the cutting force.
The machine, tool holder, workholding, and cutting parameters all work together.
Final Thoughts
CCMT and CNMG inserts are not competitors. They are designed for different machining conditions.CCMT is a great choice for:
- Small CNC lathes
- Lower cutting forces
- Better surface quality
- Heavy roughing
- Larger machines
- Higher productivity
- Strong cutting performance
The best insert is the one that matches your machine and your machining application.
I would be interested to hear what inserts other members are using on their CNC lathes. What has worked best for your machines?
BeyondMachining
CNC tooling knowledge sharing:
https://cnchome-beyond.com/
Turning tools | Carbide inserts | CNC machining solutions
