- Nov 8, 2011
- 1,678
I finally mounted my collet chuck to the mounting plate, I must say I'm quite disappointed in the quality. It doesn't operate very smoothly, the tolerances were very poor, the collets I got were very light weight and poorly deburred, After looking at the Hardinge ones at work they don't even compare.
I chucked a piece of steel rod in the 4 jaw at work and turned it to 1.00" then put it in my lathe 4 jaw and trued it up, chucked the 1" collet in the collet chuck and slipped it over the 1" rod then tightened it down. I then faced off the mating surfaces and then trued the inside of the outer ring that the bolt holes are in. After getting that done I mounted the backing plate on the lathe spindle and turned it to fit the recess in the collet chuck. It fit perfectly.
After filing all the burs off I assembled it and put it on the lathe, I chucked a 1/2" pin from my gauge pin set. I indicated it and unfortunately I have .0035 total run out. Here's some pics and videos (not in ant specific order)
