- Mar 15, 2019
- 708
Everyone has a cell phone and everyone likely uses it in the shop. Last night when I went to bed I plugged my phone in and drifted off to sleep, when I woke up my battery was at 3%. I unplugged it and plugged it back in. "Check your charger cable and make sure you have a proper connection, if you use a case, you may need to remove it".
Well, I have had a case but I have had it since I got the phone not that long ago, but what the heck, I take the case off and plugged it back in. "Check your charger cable". So I went and found another cable. Wouldn't be the first time a cable has gone bad on me.
New cable plugged in. "Please check charger cable." Aaargh. Find another cable, same thing. Try a different power source. "Please check charger cable".
At this point I am looking at new phones and surfing the web looking for a solution. No help with the solutions. New phone it is. Dammit.
But then I looked close at the charger port and there seems to be something silver on the side of the blade the micro USB slides over. I dig out a needle, it is a very tight space. I manage to catch the edge of it with the point of the needle and pried ever so lightly and "Pop' it lands on my t-shirt. A nice little aluminum chip that was perfectly wedged into the charger port. It is about .020x .020x .050 and just the right size to fit and perfectly keep the charger cord from making complete contact.
I have had pocket lint get in there before but you can see it easily and tell that it doesn't belong there. This piece actually blended in and looked like it may belong. Phone is now charging happily. Just thought i would share the experience and maybe save some frustration.
