Center Height Gauge for 820 -- What do you do?
tmenyc
H-M Supporter - Gold Member
Oct 18, 2018
465
In case you see both boards, yes I've also posted this on the groups.io board.
I'm puzzled by what to use for an accurate center height gauge on my 820. The saddle support arms extend too far forward to mount anything across the ways close enough to the QCTP, and the base is too pitted and covered in oil and chip to stand something there that would reach up to above center with repeatable accuracy. Can't attach anything flat to the cross-slide, because it's sloped and also somewhat scarred with old paint. While generally I turn the QCTP and touch off the tailstock taper, I'd like to not have to do that every time. Finally, the work I'm going to be doing will be pretty small, so I'll need precision; the "close enough" of the 6" rule trick is not precise enough. Would appreciate learning your ideas or solutions.
thanks,
Tim
I've got one of these that does a great job:
You simply put the angled side up against your workpiece (it works best if you've taken a cut since putting it in the chuck), then put the other side on the top of the tool. Raise/lower the tool until it reads level and you're there!
The rule is actually fairly accurate if you have a piece that is concentric with the spindle axis and it is fairly small in diameter and the cutting edge is making point contact. Another device that works fairly well is this:
1565703993478.png It also relies on the workpiece being concentric with the spindle axis and the lathe being level front to back.
A third option is to cut a piece of stock that can rest of the lathe ways and is just long enough to touch the spindle axis. This allows you to set the tool height with no work in the lathe. I believe that Joe Pieczynski did a recent video on making one.
I set mine up with a dial indicator which allows me to precisely set offsets from the centerline. I made a custom stnd for a dial indicator and a calibration standard. Post # 3 in this thread. https://www.hobby-machinist.com/threads/making-tips-for-a-dial-indicator.67209/#post-561864
thanks for the quick responses. I'm looking for a setup that does not depend on having work in the spindle.
RJ, the other issue is that I can't mount a magnetic base on the cross slide; it's sloped and with a rough finish from old paint. If it were just the paint I'd clear that off, but the slope makes it pretty impossible to mount anything. I'll look up Joe Pieczynski's video.
thanks again.
Tim
Another option is just to place a shim between the tangent of work and the cutting edge. A small change in height will drasticly change the angle of the shim, no need for a bubble level as shown. You can also scrip a line in on the tail stock quill, provided that the quill does not rotate much in the housing. Fast forward to (3min 25sec)
The success of using a rule to set the lathe tool height depends largely on the ability to detect small deviations in angle. For 1" stock, a .01" offset will result ind the rule being off the perpendicular by .37º. Without a reference, it would be difficult to detect that difference by eye. In addition, using zero relief tooling like N type carbide inserts present a flat vertical face and the work making contact with the rule anywhere opposite that face will result in the rule being vertical. This is especially bad for that type insert as the tool must be at or below the center in order to cut.
Adding the bullseye level vial to the rule as in the post above improves the situation but it would be well nigh impossible to set the height to within a thousandth or two.
A comment on the need to set the cutting edge of lathe tool exactly on the lathe centerline. In any turning situation, there is a line between the axis of the lathe and the edge of the cutting tool. That line can be above or below the horizontal and the tool will still cut as long as the proper relief and rake angles are maintained. Raising a tool has the effect of decreasing the relief angle and increasing the rake angle. The opposite for lowering the tool. The following illustration shows two different tools that present exactly the same rake and relief angles to the work simply by changing tool height.
There is an effect on the forces with regard to rigidity but any lathe is a complex system of forces that varies from lathe to lathe by virtue of its design. I suspect that is why a particular recipe work well on one lathe and totally fails on another. The other side effects are that when the cutting edge is offset from the center line, moving the toll a thousandth does not take two thousandths off the diameter when cutting threads you vcan only have correct thread geometry when the tool is horizontal with the spindle axis, and cutting below the centerline leave a nub while above the centerlin will shear the nub off with the non cutting edge or, if the difference is great enough, deflect without cutting.
If you crank the cross slide forward, that exposes the dovetail of the saddle. Is it possible to perch a height gauge there and swivel the tool post to reach it with the tip of the tool?
RJ,
This is exactly why I, with my first lathe and a vintage lathe to boot, want to know its accuracies and inaccuracies, so want to be precise before long habituation allows me to let down my guard a bit. I appreciate the directness of the writing.
Mike,
Don't know! But will find out tonight!
Tim
Mike,
Reaching the point of a tool from over the cross-slide is not possible with the indicator stand I have, not by some inches. I have not yet invested in Noga, and my cheapo stand just doesn't go there.
Others,
Many thanks for the responses.
I think, for now, I'll face a 1.5" x 4" piece of aluminum rod I have, mark its center as exactly as I can, scribe a line across that center, and chuck that in place when I need it. Much as I like Joe Pieczynski's idea, I just don't have the flat space to place anything. And, as others have noted, the more I dedicate AXA tool holders to particular tools the less often it's actually needed, so I'll do this until it gets annoying, then figure out Plan A.
Tim
