- Jun 26, 2018
- 1,733
I am using the servo/stepper setup (is this not a hybrid of the two?) Are you saying that the 2:1 pulley setup is a stronger/torquier setup? I'd rather make the small changes now before it all is put together in the machine. Sounds like I should also use a different pulley setting. I was excited for that 50 rpm threading speed, but I was kicking its butt at 130rpm
