Change Gears for SB 9”C model (FOUND ! Thanks)
frankly2
H-M Platinum Supporter
Mar 27, 2017
194
Having trouble finding gears, maybe I should buy blanks and cut them myself ? Any suggestions ?
for my old lathe I was able to buy some gears from Boston Gear. you do need to know the full gear specs. I did have to modify some of the hubs.
another idea is 3d printed plastic ones.
the (free for home use) fusion-360 has a built in spur gear generator, so you could produce your own files. also you could check the website thingiverse to see if someone has already created them.
-brino
