- Aug 1, 2018
- 16
Having finished x and y dro looked next to z.Had this cheap digital caliper which I didn't like, looked like a good place to start.One slight mod to caliper frame with a .093 wiz wheel,(4) 8-32 screws and one 10-32 bolt,spacer and aluminum mount.All sourced from cubbyholes.Two hours and works like a champ.By loosening bottom 10-32 bolt and loosening left hand 8-32 socket head you can remove caliper,saves the battery because even when you hit the off button the next movement turns it back on.I checked it with the machine dial and also with gauge blocks and caliper was more accurate than the z feed dial.
