In an effort to get a better finished product, I have started using a lot more carbide end mills than I did in the past. The problem is that at the higher speed I am running the mill I end up with chips every where, and I mean every where. Will a set up like wood workers use to keep saw dust down, by using a vacuum machine on their table saws and routers, work with the heavier chips made by metal working machines. I clean the shop daily with a vacuum, but will it work catching chips flying off the end of a carbide cutter? Maybe such a set up is already available and I just haven't seen it advertised. Any suggestions? Any plans?
