I’m really stuck! I had to take off the front of the gear cutting selector box to find out why the gears where difficult to select. I managed to do it without taking off the gear selector lever, but clearly to put it back on the lever needs to come off. After a few hours of fiddling, looking, thinking, fiddling again I've come to the conclusion either I’m missing a fastening or it’s truly stuck on. I’d really appreciate knowing how to take it off.
I found two grub screws that I’ve removed (nit shown in the manual), one in the centre and one that acted to maintain the index of the arm. I’ve tried to see if the indexing grub screw would also act as a jack to push off the lever, but either the lever is crudded or, the threads don’t go all the way through.
OK, I accept that this is a question I shouldn’t be asking, as I should be able to work this out myself if I’m ever to hold my head up as a metal chip maker! but I left my pride behind years ago and would welcome any help.
I found the cause of the gear change problem, the selector tumbler and gate had been abused and the tips of the gate were bashed. A quick file sorted them out. I was surprised that the metal used is very soft and not hardened. It was also a good opportunity to clean out area out. I’m not sure it had ever had an oil change! Luckily all the gears had all, their teeth. The gear box picture is before it was cleaned.
On a different note, I can’t see how the oil gets between the two galleries, there are two sump plugs for draining it, and the central pillar of the case has a gasket that runs up so nowhere for the oil to sneak around that I can see? The oil filler feed just one side.
