Go with the smaller one, with the larger one, the thin sides of the threads in the nuts are too thin, and will likely crack if tightened very tight; been there, seen that. This does not happen if the studs are screwed in all the way to the bottom of the nuts, but with a little crud collecting in the bottom, sometimes they do not get screwed All the way in; been there, seen that too ----
Just be sure that the wider (lower) section of the T-nuts is wide enough to safely span the slots on the table! For a 16mm slot, I'd be concerned about the width of the M12 T-nuts.
