I recently acquired a Clausing 100 mk3 in quite nice condition and have begun tuning it up. One of the first things to tackle is getting the preload right on the spindle bearings. Some searching has turned up that "the chuck should go about 1 revolution when turned quickly by hand." My question is in what position should the lathe be in when performing this test? Back gear off is obvious, but should the belt be under tension? Should the clutch be in or out?
