- Nov 11, 2018
- 9
New to me, and likely older than me, also.
I wanted to put a couple bits of information here so the Google Machine can find them, and also ask a question and see if anyone knows.
This beast is Ser. Nr. 503970, with 2215 power downfeed. 220V 3PH, magnetic starter, rotary switch with two forward speeds and one reverse, all variable through a Reeves Drive, which seems to work OK. It was in a production machine shop for a long time, and then was purchased by the auto shop next door when the machine shop retired. I bought it from my mechanic when he retired, and am just getting into cleaning it and making it newer again after three years sitting in the back of my shop.
Step one was getting power to it. Back In The Day™ it was apparently normal for 3PH magnetic starters to have only two heaters/overloads; news to me, but it runs.
Step two will be getting new belts on it, and here's the info I have/need - the Reeves belt is a 1930V425, the triple drive belts are 4L260, and the five-rib poly-v belt for the down feed is....? Anyone know this one from experience? According to the manual for the 2215, it's Clausing P/N 051-030, which I can't find a cross reference for. After I have all the belts in hand, off come the existing ones and...
Step three will be to clean ca. 35 lbs. of dust, brake rotor dust, train dust, oil & dust, fuzzy stuff, and other dirt off this poor thing. I am thinking that odorless kerosene would be the best cleaner that won't attack components and will leave a light film behind to start the next dust collection. I'm all ears if there are other suggestions - I was planning on making a kiddie pool for the drill press, dumping a couple gallons of kerosene in it, cycling it back through a filter and hose, and rinsing and brushing the whole monster until it's looking like a machine again. Again, all ears for suggestions that make more sense.
Now I have four drill presses....and a friend who wants me to take his ca. 1950 Walker-Turner. How does this happen??
