Hi all.....I just acquired a Clausing 6300 and as part of the cleanup I will need to change the oil in the headstock, gear box, and apron. The manual calls for SAE 20 oil and SAE 90(for the gearbox) Is there an equivalent for these? I had read that ISO 68 is and equivalent for SAE20, but want to get some opinions before I put the wrong stuff in there. Also, is it enough just let the oil drain and then fill to the proper level or should I flush these areas with something after draining? I don't see any clumps or sludge so I don't know if flushing is absolutely necessary , but if I should flush it could I use kerosene?
Thanks
Thanks
