Clausing 6329 lathe
Shootymacshootface
I make little metal out of big metal.
Mar 17, 2018
1,400
I just picked this up Saturday. I found it on Craigslist. I still cannot believe what was under 20+ years of grime. There were a few things that needed adjusting, everything needed to be lubed. I changed the oil in the gear boxes, cleaned the grime and surface rust off of the chuck and all of the handles. It was wired for 480 3 phase, so I had to change it to 220 3 phase. Everything seems to work on this machine, the only thing that I can find wrong with it is that the knobs are missing for the two storage draws. It came with some tooling as well.
I couldn't be happier with my Craigslist find. I can'twait to make some chips with it!
Really nice shape! Congrats!
Mark
ps why do they mount the drum switch in such an odd place?- grrr
I would have put it on the cabinet-
Thanks! Tubalcain is teaching me how to use it. I didn't realize that threading was so complicated. I'll just do it step by step untill I am familiar with the process.
I have a Clausing #5418, baby brother to your lathe. Really nice lathes by the way. Curious how you shift your QCGB. Looks like it has the typical Clausing LEFT, CENTER, RIGHT lever up top. Must shift the lever to the left up/down to change gearing? Plus you get the elusive 27 tpi.
Bruce
The two knobs sticking out of the belt/gear cover do the shifting. The cylindrical knob on the top is for an in or out position on the sliding gear. The lower round knob does the gear selection and there is a red indicator that you can see thru the window with the chart on it.
Looks great, nice find.
Do you have three phase in your shop or are you using alternative method to power it?
