Cleaning And Painting Wells Index Model 745
azshadeguy
Jul 16, 2017
146
I finally got the 745 in the garage.
I am in the process of tearing it down and cleaning.
One thing I found is that the head will not rotate to the left or right .
I loosened the screws and turned the bolt and it just spins.
It looks like they put a light coat of bondo or something to cover blemishes on the castings. My question is
is this bondo or something else? Should I pull the rivets and remove the nameplates prior to painting?
4
4GSR
Forum Guest
Register Today
There is a worm gear inside the mechanism that is probably has some teeth strripped off of, which is not allowing the head to rotate. I would suggest removing the motor and whatever else you can and grab ahold of the head with a engine hoist or a overhead hoist and carefully remove.
The bondo looking stuff is a filler that W-I used for smoothing out the castings before painting. Have no clue what kind of material it is. Sand lightly and paint. I painted my mill with ford blue from the tractor supply over ten years ago and it is doing fine so far. Just hard to keep the mill clean from usage. I highly recommend using Rustoleum brand of paint which does not necessary require primer and use. I've used it with their primer and without, with great results. If you can remove the name plates without damaging them, do so. Most of the time, I cover them with painters tape and it does fine.
Glenn Brooks
H-M Supporter - Gold Member
Nov 14, 2014
801
Yes, Rustoleum is ok, I've found it chips badly until it dries for a month or two, then it slowly gets harder and more resistant to dings and wear. Much better to find a polyurethane or maybe one part epoxy if you want a hard, chip resistant surface.
I took the inspection plates off my old Dalton Lathe when I repainted it (rustoleum). Then got some brass rivets to reinstall them. Used brass split rivets to put plates back on the thin gear covers on the end of the headstock. You can spread the back end of a split rivet with your fingers - so no banging on thin cast iron parts!
Glenn
markba633csi
Apr 30, 2015
4,442
Yukko muckko what's that yellow stuff Shedd's spread? And that green stuff leaking out looks like something died in there
LOL
Mark
azshadeguy
Jul 16, 2017
146
You were right the cavity was full of shavings and someone must have tried to turn it without IMG_1697.JPG IMG_1698.JPG IMG_1699.JPG loosing the the bolts
4
4GSR
Forum Guest
Register Today
You were right the cavity was full of shavings and someone must have tried to turn it without View attachment 244246 View attachment 244247 View attachment 244248 loosing the the bolts
If you don't support the head as you are tilting, it can catch and strip the teeth. And I agree, they probably didn't have the bolts loosen enough either. I try not to tilt the head. I have a all angle vise that comes in handy when I need to cut some sort of angle. Now, I do nod the head once in a while and haven't had a problem with this. Of course, I haven't taken it past 30 degrees either. I believe the gear is replaceable. I haven't tried to remove it on my mill. And I'm sure W-I stocks that gear, too at not too bad of an price.
4
4GSR
Forum Guest
Register Today
When you go back together, I suggest to use Lubriplate 105 grease or equivalent. Please don't use EP-1 or 2 grease in the head. That stuff just cakes up and does nothing for you as you see in the pictures. If it was my mill, Some of those areas I would use just good o oil for lubrication.
azshadeguy
Jul 16, 2017
146
The gear that is stripped is one piece and holds the head
azshadeguy
Jul 16, 2017
146
i found this on the web
>Wells-Index Division, A and D Machinery Company
>Muskegon, Michigan 49441
>United States
>Vertical Milling Machines
>Vertical Spindle Bearings
>Mobiltemp SHC 32 , Mobilith SHC 15
>Vertical Spindle Power Feed Gearbox
>Mobilgrease XHP 220
>Pulley Bearings, Table Lead Screw Bearings & Knee Elevator Thrust
>Bearings
>Knee Elevator Bevel Gears
>Mobilux EP 2 , Mobilgrease XHP 223
>Vertical Spindle Oil Cup, Knee Elevator Crankshaft Bearings, Ways,
>Slides, Spindle Quill Trip Mechanism & Automatic Lubricator
>Mobil Vactra Oil No. 2
>Lead Screws, Elevating Screws & Spindle Splines
>Horizontal Drive Transmission, Overarm Arbor Support
>Mobil Vactra Oil No. 4
4
4GSR
Forum Guest
Register Today
Might inquire, they may make a gear to replace that one with a little rework. If not, find one to a Bridgeport and see if it will work. Still have to cut off the existing one to replace. Just a thought. As far as that goes, make one!
T. J.
Oct 31, 2015
335
Kieth Rucker has a video on YouTube where he replaced the worm gear on his W-I mill. I think his is a Model 845 though.
azshadeguy
Jul 16, 2017
146
I was talking to some folks on shop floor talk and they think that the teeth could be welded up and ground down to the correct profile
azshadeguy
Jul 16, 2017
146
Thank you after watching that video I can see that it is not a single piece Wells may have a replacement gear
T. J.
Oct 31, 2015
335
Another option might be to rotate the gear 180 degrees to get the damaged section to a spot where it will never be engaged.
azshadeguy
Jul 16, 2017
146
That's what I did. I emailed Wells Index and the gear is available for 230.00
4
4GSR
Forum Guest
Register Today
Ouch! Not as expensive as I've seen with other gears and stuff from other "old" machinery companies.
Might not get to eat lunch for a month to pay for the gear. Just a though on funding.
azshadeguy
Jul 16, 2017
146
I have ordered some grease and some bearings for the 745. I hope they get here soon before I forget how it goes back together
azshadeguy
Jul 16, 2017
146
Well I got my bearings and they sent one of them wrong.
It was supposed to be sealed on both sides and is only sealed on one.
azshadeguy
Jul 16, 2017
146
Can some one tell me if all 3 of these bearings are the same?
I didn't take enough pictures and I am stuck
AdBlock Detected
I've Disabled AdBlock
