- Dec 31, 2010
- 937
I have a tracktor with wet type multable disk brakes and the left hand one seems to be locked up. After dismantling the brake I washed the disks in Stoddard solvent.
After washing I noticed a stain on the precision block which I thick is from the oil in the solvent. I used a dry industrial paper towel to wipe the stone but the stain is still there. I am considering the use of alcohol or acetone in an attempt to remove the stain. Two questions are Should I not do this and is there a better alternative? FYI The maximum warp in the disks is 0.003" in one friction disk, 0.0015" in two others and two steel fixed steel disks with 0.0015" warpage. the operating camber shaft is in a place that is difficult for oil to get to and I believe it filled with dirt or grime during the past 10 years of operation. Will know more tomorrow after re-assembly. Any help or information will be appreciated.
Ray
Ray
