Your wish is my command O Lover of old iron
The Harley was a basket case WLC with a bent frame, I straightened it, added a 10" gooseneck with 12" over springers.
All work done by me except the forks. I bought those.
The only engine mods were raised compression, flowed the inlets and dialed in an 1.25" S.U. carb (that took ages) along with an oil cooler and spin on oil filter, suicide clutch and jockey shift.
It handled beautifully even with that extended wheelbase and rake.
The Triton had a Triumph Bonneville pre unit engine with e3134 cams, gas flowed heads, twin amal concentrics and iirc 12:1 compression mated to the norton gearbox and clutch in the Norton Featherbed frame and forks
The fuel tank has oil one side and fuel the other side with the speedo, rec counter, oil gauge, amp meter set in the top which you can just make out .
The side panels hold the oil cooler and hide the oil filter and battery. No disk brakes in those days but a huge twin leading shoe drum.
Again all work done by me and scored a first in a local custom show. Second was a Velocette Venom sporting one of my paint jobs, black with classic gold leaf pin striping (gee I got a big head
