CME Mill Vice?
I have not bought a vise from CME, but I have bought many other things. Some of the items are a chuck, several L00 backplates, and various tooling. All items seem to be CME branded imports, and I have been more than satisfied with everything.
On import Kurt clone vises, which are very ubiquitous in the hobby community, they seem to be within advertised tolerances. The only thing to be careful of with them would be when clamping on only one side of the jaw. Always use a machinist jack on the other side. I have a Shars 6" Kurt clone at work that my gorilla assistant tweaked the body of the vise by unevenly loading the jaws.
That is a really good price for that one. I would say to get it.
I bought a Shars 4" Kurt clone in 2013 for about $140. Finally, 8 years later, I did a full analysis of the accuracy and found it atrocious.
If you go this route, I'd make sure you have the capability to evaluate the accuracy of the vise to see if it meets specifications, and have recourse to return if it does not.
My concern, besides accuracy, is how strong the iron castings and lead screw nut are. Sometimes I really crank on my Kurt vise but feel confident it can take it. Also the nut on a Kurt is 4 to 5" long.
Cheap enough for sure, I had an old friend who had a saying about cheap tools "the only way you could get hurt is if you try to use it"
Thanks for your inputs. My thought was that I can buy this and replace it 3 times for what a Kurt costs. As long as I don’t go 600 lb gorilla on it, being that I would likely be the only user, it may survive a while.
I like the suggestion of using jacks to keep the jaws squared up.
Any more advice or first hand experience is always welcome!
As someone who typically doesn't mind buying 'cheap' tools under that attitude, the vise is the one thing I wouldn't skimp on. The problem isn't durability (though that is a problem as well!) it is poor construction quality that ends up making you screw up 'easy' things because your vise flexed, was inconsistent, fell out of tram, etc.
That 6" vise is the same one that Precision Matthews and numerous others sell to various levels of quality control. Macardoso's recent adventure with one shows the quality you get out of them. Additionally, someone recently had a problem with jaw lift on them on this same forum.
FWIW, having owned both, i would never again own one that wasn't Kurt, Orange, Glacern, or one of the similar ones.
That said, what size mill are you going to use this on? That 6" might be too large for your machine (a mistake many of us have made), and you might be better off with a 4" screwless vise (tend to be better made, even the 'cheap' ones), or the Glacern 4": https://www.glacern.com/gsv_440
Erich, thank you for your insight. Having a 6” vise being too large was actually something that hadn’t crossed my mind, I was thinking the bigger, the better. The machine has a smaller table I believe, I haven’t gotten it home yet, and haven’t measured the table yet. I posted here some pictures and what info I have on the mill. I have plenty of time to shop for accessories since I am going to have to go through this thing thoroughly, I will keep eyes open for a good deal on a used Kurt maybe or the like.
I don't have a good idea of the scale there, but it appears to be a full-size clone or so? So a 5 or 6" vise would fit just right. I think your plan to keep an eye out for a used Kurt/etc is likely the best idea. A new Kurt 6" is about $550, the Glacern is about $350-$450 (depending on size), but used Kurts show up often-enough in the $200 range on ebay or craigslist. Its worth the wait!
I have the 5” version of the CME vise for my 9-1/2 X 32-1/2 mill table.
It is amazingly accurate for a “budget” vise. Maybe I just got lucky.
I did disassemble it and smooth the half ball and the socket it rides in & I have no jaw lift.
I have no problem with the CME tools I have purchased.
Cheers
