Compound slide retainer missing
derrabe
Nov 25, 2019
1
I have a 9b-17-1 Logan that I aquired last week. The retaining mech for the compound slide screw broke or is missing and I can't seem to find it or a part number or what it is actual called to get a replacement. So it just now unthreads and threads but won't move the slide.
Sent from my SM-N975U using Tapatalk
brino
Confirmed Tool User
H-M Lifetime Diamond Member
Jan 2, 2014
5,073
Hello and welcome to the group!
I am not familiar with the Logan models numbers.
There are a few manuals available here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=2093&tab=3
Have a look, maybe you can find an exploded view and part number.
I believe some parts are still available for Logan machines.
Hopefully a Logan expert will stop by this thread with some real answers soon.
Good Luck!
-brino
Chuck K
Mar 1, 2013
1,117
I'm trying to figure out which part you're missing. Is it the threaded collar that screws into the compound?
wa5cab
Downloads Moderator
Staff member
H-M Platinum Supporter
Dec 25, 2011
8,235
I'm not a Logan expert, either. But 9b sounds more like a South Bend model number than a Logan. Logan model numbers all seem to be 3 and 4-digit. For example, a Logan Model 400 is one 9" lathe family. Best bet would be to start with a photo of the machine's nameplate. And one of the carriage, cross slide and compound.
brino
Confirmed Tool User
Jan 2, 2014
5,073
A few pictures sure would help.
-brino
Nogoingback
H-M Supporter - Gold Member
Oct 18, 2016
1,947
Here's a PDF of a larger Logan than yours: not the same machine but there's a good chance the compound
is put together the same way. If you remove the compound you can see if the compound rest nut is present:
if the handle turns but nothing happens the nut is probably the culprit.
You can also contact Logan directly by phone: they have the correct parts manuals and operators instructions for your
machine, and can supply parts as well. http://www.lathe.com is the link.
As brino said, you can also post pictures of what you have and we can help you that way.
rambin
Jul 29, 2013
237
what we really need to know is....is the screw thread turning.. the part under the compound... there should be a removable panel there covering the threaded rod from chips... or when you turn the handle is it just slip;ing on the threaded rod that is suppose to move the compound. there is a sleeve joint on mine that has failed... unbolt the saddle take it off have a good look.
Nogoingback
Oct 18, 2016
1,947
Are we talking about the cross slide, or the compound? The OP, who seems to have gone AWOL said compound.
Chuck K
Mar 1, 2013
1,117
I was thinking compound. From his description it sounds like the screw is backing out of the compound casting instead of pulling it back.
rambin
Jul 29, 2013
237
hmm I misread I guess... I don't know whats going on then... hopefully he returns with pictures....
AdBlock Detected
I've Disabled AdBlock
