[4]
Conversion Of Mill Motor From 110 To 220 Volts
[3]
[10] Like what you see?
rock_breaker
H-M Platinum Supporter ($50)
Dec 31, 2010
552
Likes
265
#1
My Enco mill is equipped with a 110/220 volt motor that is currently running on 110 volts. Inside the connection box on the motor is s diagram showing connections for either voltage, and in order to connect it for 220 volts a coupling link must be moved. My question is: after the coupling link is moved and the 220 volt connection made according to the chart does this require changes in the forward/reverse on/off switch?
All help will be appreciated.
Ray
JimDawson
Global Moderator
Staff member
Feb 8, 2014
7,389
Likes
5,639
#2
Changing the motor voltage should not effect the controls.
fixit
Feb 8, 2014
215
Likes
100
#3
Did not on mine.
fixit
ARKnack
Active Member
Dec 19, 2014
164
Likes
91
#4
Most switches are rated 120/240v. I assume your switch came with your machine. if so, it will have the proper rating. The other thing is a 240v switch needs to break both incoming wire circuits. Pop the switch cover off and see if both wires (white, black) are wired to the switch with two other wires going to the motor. If so, then your switch is wired for 240/120v already.
rock_breaker
Dec 31, 2010
552
Likes
265
#5
Got a new battery in the multi-meter, three power supply wires come into the box, white, black and green.
five wires go to the motor white, black, brown, yellow and green. The white wires are closely positioned so checked them, no continuity from" power in" and "motor supply" out. Thanks guys!!!
Have a good day!
Ray
tcweb
H-M Supporter - Silver Member
May 25, 2016
30
Likes
4
#6
Hi rock_breaker, this is an old thread, but would you be willing/able to take some pictures of your wiring on your drum switch and motor connection block?
I'm trying to figure out why my Enco (110v) is running opposite what the drum switch tells it to.
BaronJ
Brass
Aug 7, 2018
660
Likes
337
#7
Hi Tcweb,
You need to swap the ends of one of the windings, unless its a DC brush motor, in that case just swap positive and negative wires to the motor.
[6]
[5] [7]
