So... I was using my 5900 and when I was turning the variable speed control I heard a pop. Variable speed was kind of locked. It actually felt like it turned too far. This had happened before and I’ve honestly never been able to figure out what happened. I end up disassembling everything and then putting it back together. Then it works. It feels like the cam that contacts the roller push rod turns too far. I know that there’s a roll pin which prevents it turning too much but I haven’t been able to see anything wrong with the way I have this put together.
So...I unbolt to top dial....take out the main clock-spring...and unscrew the 4 bolts attaching the master cylinder bracket to the lathe.
I then unscrew the hose. Inspect. And unscrew the set screws from the master cylinder bracket which attaches the cylinders. Everything looks ok. I put it back together. Start up machine and run it up to speed. All good. Then about ten minutes later...add a little more oil...and again start turning up to speed. AND CRASH. I’m looking at the master cylinder hanging out of a shattered cast iron bracket.
by the way...just a note on this picture. It’s a picture after I tried brazing it. You can see a couple of spots where it stuck. But I wasn’t getting a good flow around the cracked pieces. I should have tried a rosebud. It’s probably been a year since I last brazed cast iron. Like everything....practice makes perfect. I should have practiced my brazing before attempting this. Really am out of practice with my O/A skills.
