[4]
Crayford focusser for finder scope
[3]
[10] Like what you see?
savarin
Aug 22, 2012
2,026
Likes
3,091
#1
Started with a bunch of these
to make a bunch of these
One of which was faced on both ends then squared on two sides then drilled for a 4mm shaft.
Then mounted off set in the 4 jaw but only using 3 of the jaws and bored out to just enter the side of the 4 mm hole.
It was then mounted between a pair of mandrels to turn off the surplus.
leaving this small curved part.
The 6mm angle has 4 x 10mm bearings that the focusser tube slides against.
These are then bolted to a small plate
A tube to hold the eyepiece is added
Then mounted to the finder scope tube
The 4mm stainless shaft moves the tube in and out by friction alone.
BaronJ
Brass
Aug 7, 2018
660
Likes
337
#2
Hi,
Nicely done. Could do with some blacking to cut down reflections.
savarin
Aug 22, 2012
2,026
Likes
3,091
#3
The inside is fully blackened. I use artists Atelier carbon black, its the blackest black I've found to date.
rwm
Mar 25, 2013
1,498
Likes
1,694
#4
Very slick. Is there a way to adjust the fit of the tube or do you just have to get the diameter right?
Robert
dtsh
H-M Platinum Supporter ($50)
Sep 22, 2017
126
Likes
135
#5
Nice, now you have to make a dual speed crayford. :p
savarin
Aug 22, 2012
2,026
Likes
3,091
#7
I made this one to the exact size but did place a screw and pusher to press the shaft against the tube but in practice it hasnt been required.
I may make a dual speed for my bino when I get that far and will use three balls pressing on the main shaft held with a cone.
Turning the main shaft is the coarse feed and turning the cone is the fine feed utilising the three balls as a planetary gearbox/drive.
I made a simple test and it worked pretty well.
BaronJ
Brass
Aug 7, 2018
660
Likes
337
#8
Thank you, I did wonder what you used.
[6]
[5] [7]
