- Dec 25, 2011
- 10,477
On the Compound slide, replace the middle one. It will have the least effect if you loosen it to move the slide and forget to adjust it. On the cross slide, the 2nd or 3rd, probably the 3rd. Note that if you use the milling attachment lock screw, if it is turned so that the cross bar is vertical, the bar will hit the saddle wings. So watch that and when loose, be sure that the bar is horizontal
